Disk break lock cannot remove
  • bloodog
    bloodog
    Went over seas for a Holiday seen this on a local face book $30.00 used thought it a good idea for some extra security
    Put it on and 5 months later fuuuuuck ing thing will not undo
    Any body got ideas before I pay a  locksmith
    Take wheel off unbolt disc  take to it with a angle grinder
    Whilst swearing a lot about the quality of shit on the market
    Today lol ??
    Lol how minds think alight
  • Kingchops
    Kingchops
    Use a spray can of lithium grease or RP7 with a nozzle.  Spray inside the lock mechanism and let it sit for a while, even over night.  Then try to un-lock with the key.  I've had this happen on many locks (not disk locks, but the concept is the same).  What happens is a bit of moisture gets inside and causes the locking mechanism to rust slightly which binds it up.  What I'd also do is rotate the wheel so the lock is at the bottom.  This way the keyhole is at the top and gravity will allow the spray to work it's way down through the mechanism.
    If that fails, use an angle grinder like others have suggested.
    Agree with Kingchops, WD 40 the internals of the lock as well as between the lock aiming for the pin. Leave overnight and while tuning the key in the lock use a rubber mallet or hammer and GENTLY tap the lock from either side. The pin that goes through the disc may well have rusted/corroded not allowing it to retract. Don't  forget most importantly when it does release clean the disc with brake cleaner to remove all traces of WD 40
  • bloodog
    bloodog
    Thanks dw40 ING now
  • markwoumla
    markwoumla
    Lot of good suggestions above ....
    Better still ,,,, take it to a doggy part of  town,,,,   have a stake out close by with a good view of the bike ,,,,, and let the experts unlock it ,,,, sling the guy 10 bucks when his finished ...... Sorry Bloodog ,,, I couldn't help myself .........
  • LOFTYBOB
    LOFTYBOB
    The price you pay for pissing off overseas and leaving your pride and joy alone for a while.
    With the Darwin humidity, I concur with the corrosion in the locking mechanism theory, RP-7 or WD-30 away.
    graphite powder works good in locks too.
  • Baloffski
    Baloffski
    Fuck all the girlie powdery shit, .45 works every time.
  • Baloffski
    Baloffski
    Fuck ya got me there..
  • robnicko
    robnicko
    bugga !
    thats always been a fear of mine with those disc locks
    if the wd40 dont work the pin is usually hardened steel but if you can get the wheel off and remove the disc, a hack saw blade and a 6 pack should see you through
  • Ferrett62
    Ferrett62
    The one I have has a cord you loop over the bars to remind you to remove it.
  • Wideglider
    Wideglider
    True, I have noticed the newer ones have the cord - good idea.
  • gidgi
    gidgi
    Although it would be hard in that position For future reference soaking in vinegar breaks the bond that corrosion makes especially good for rusty threads & the like
  • bloodog
    bloodog
  • bloodog
    bloodog
    Got it removed not a scratch or grind mark on my disk or frame, now a good wash down spray my disk with cleaner and yes I cleaned the disk befor moving the bike so not to put slit into my break thank Fuck for that. Locksmith quoted at least $100.00 and could not look at it for 5 days Thanks for all the replys
  • robnicko
    robnicko
    I see you used the master key !
    That's my favourite 'adjusting' tool as well!
  • steelo
    steelo
    Hi BD. Was a good thought about the bike lock. Shame it didn't pan out. Time to sell the bike me thinks before incident 3.
    It's only been less than 3 days since you first posted, did you try any of the other less extreme methods?
