Battery access panel
BLK883
Hi All,
Having a few issues with my battery access panel popping off while riding, seems like the top two clips aren't holding it properly at speed. Any tips/tricks to keep it locked in?
There's a cable velcro tie method, but the one I like better is just drilling a hole through one of the plastic clips and then just putting something in there that wont fall through - plastic cable tie or one of those pins with a ring on them...
And I found a video:
Click here to watch video.
shadowarrior
I opted for a re-usable cable tie option for the left most hole, normal clips for the other two so the cable tie stays hidden and still easy to access. :) Supposedly HD made some new mount clips which fixes this problem, forgot the part number :\
BLK883
Thanks lads, went the Velcro option. Seems to be doing the trick for the time being.
