FXSTC Indicators
  • Old Syd
    Old Syd
    Hi all,
    another problem I have with my 93 Softail is the Indicators only stay on for 10 seconds,
    is this normal?
  • oneup
    oneup
    what year ? we both have evos...mine stay in forever. Springersues bike has had a timer or mercury switch fitted at some stage so it cancells.
    you can now buy fully adjustable timer relays on ebay from asia for a few bucks
    What one up said  maybe a badlands timer has been fitted,
  • Wideglider
    Wideglider
    A fixed timer won't take into account your speed - you need earlier flashing activation with an accompanying longer duration flashing when travelling at 120km/h than you do travelling at 20km/h.
    My '96 WG has a turn signal canceller, do you not have this? If you have a workshop manual it will mention what your bike has.
    Mine cancels depending upon initial speed when activated then cancels dependant on distance (both from a speedo output), the faster the speed - the longer distance (duration) of flashing.
    From my workshop manual below:
    He won’t have any of that he’s Bike is a 93  it has a basic flasher that’s it  from 96 up will have it as
     your 96 wideglide  anless  it has a aftermarket unit fitted such as a badlands  interface
  • Wideglider
    Wideglider
    Fair enough, I wasn't sure what year the 'canceller' was fitted - my manual mentions '95 as well.
  • Old Syd
    Old Syd
    Thanks guys, so I need to check my flasher unit/replace ?
    to get a longer flash sequence,
    I would probably prefer one that doesn't cancel at all (do it manually)
