Tri bar tailight
Tri bar tailight
Beads
Hey all, I got a tribar taillight for my 2011 softail,
it doesn’t have the instructions with it but looks to be pretty straight forward,
my issue is the two bolts on each side that hold the factory light assembly in. One bolt on each side is just spinning and won’t come out, the only reason for this I can think of is the actually nut that’s Moulded into the housing has come free from the housing and is just spinning? Can anyone shed some light on this?? Thanks in advance
Beads
Beads
Has anyone fitted a tribar light? Do these two bolts usually come straight out?
Roo Ted
Sorry I can't help you Beads.
All I can hear is crickets........
Beads
All sorted thanks, I had to cut the standard one off and put pressure on the nut with a screwdriver while I undid the bolt, as I suspected the nit was turning in the plastic housing! Cheers
