Gallery added to forum editor
Kingchops
With the latest release of the forum, I've added a Gallery button to the editor. You can now insert your existing images into new or existing posts. You can select multiple images by ticking the checkbox under the image. Doing that will display an insert button which will insert all selected images into the post. To insert a single image into the post, just click on the image.
This also makes it easier to fix image rotations. As soon as you upload an image with incorrect rotation, you can click on the Gallery button and use the rotation buttons to fix it. You can then either delete it from the post and re-insert it from the gallery or simply save the post and refresh the page (SHITFT & F5 in Chrome).
Let me know if there's any problems?
binnsy
Nice work
Baloffski
Cool ....
gidgi
always thinking mate ,great idea
Kingchops
I've also just made some layout changes to the image galleries. Thumbnails now display nice and consistently regardless of the image size and aspect ratio.
Roo Ted
Great stuff Chops, keep up the good work.
Great work KC .
Yep! easy peasy lemon squeazy. Done! good job KC.
Roo Ted
Hey look at the black bike skulking around in the background. Must be embarassed hanging out with the rainbow warriors. :-)
