Hoglights
Hoglights
softfat
Recently bought some Hoglights from Nate up in Queensland. When posted, they arrived the next day. Great bloke to deal with and glad I'm spending my dough in Australia. Harley wanted $960 for the headlight only, where Hoglights were $580 for the headlight and 2 side lights. Breeze to install.
Original lights
Headlight install
Sidelight
I suppose you can see the new and old
Old headlights
New headlights. Much crisper lights with wider field of light.
Be aware of these on the headlight. They can dislodge and if you don't see it, the headlight rings will rattle when replaced. I replaced the originals with 2 pieces of rubber hose (pictured) as the originals do go hard making for a not tight fit up with the rings.
These lights are dearer than the lights some of you guys are buying from China, but I know if these fail, they are covered by a 5 year warranty.
Soft...
graz
Look good Soft. Let us know how they go on the road at night. Thinking of Hoglights for my streety rather than the Chinese ones.
shadowarrior
Got a 7inch off Nate for my Sporty, makes night and day difference from the stock lights literally! Very happy with the lights :)
imoo6170
I have a 5 3/4 in HOGLIGHT in my XR - Great Light
