Online:
Second gear
Second gear
ToeCutter21
Got my first HD earlier this year - 2017 Fatboy S. Love it. Not a perfect bike but it does want I want.
I'm getting used to the ground clearance, the engine noise, the air cooling and heat flow. The only thing I'm really struggling with is the second gear ratio. It's geared fairly high which is nice at highway speeds but going around corners I can never work out whether to use first or second. Every other bike I've owned or ridden - second gear was ideal, but on the Fatboy it's just a little too high, and first is just a little too low.
Anyone else feel the same way? Has anyone changed their second gear ratio?
John.R
If first is too high, use 2nd and ride the torque.
Simples
Stew70
I have found this too. But have decided that 1st is better and have accepted it. Perhaps as I get used to my bike more maybe I'll get faster around round a bouts and be able to use 2nd. But for the moment 1st it is.
Why not lower the final gear ratio, you can do that via primary or secondary , if you lower primary gear ratio it will move all the gears down& not effect speedo. If secondary it will make speedo read a bit faster. What rev range are you in?
limpn
Yeah I normally go around round a bouts in 1st gives me more street cred with I smash into 2nd and let the ass end hang out.
AlHD48
I like your style limpn lol
