Brake light works but tail light doesn't. 98 FXSTC
  • gigiflip
    gigiflip
    Hi guys, I'm good with mechanical but not good with electrical so hoping someone can help.
    I had to remove my centre console and when I put it back I severed the wire that controls the trip meter reset switch. Repaired the wire and all good. However (and I don't know if it's related or just a coincidence), my tail light doesn't work but the stop light does. I have 12.4V to both connections in the bulb housing (of course the stop light side only shows 12.4V when you put the brake on).
    So, I have power. The stop light works but the tail light doesn't. Any ideas? I have replaced the bulb with new bulbs about 3 times just in case the bulb was defective.
    Cheers, Bill.
  • Wideglider
    Wideglider
    Welcome to the forum.
    Check continuity of bulb filaments - switch multi-meter to Ohms
    Check/clean (with contact cleaner spray) the light fitting contacts, check that the bulb fitting contacts haven't dislodged & been pushed too far back.
    Check that bulb sits square into the fitting.
  • baldy1450
    baldy1450
    Check the earth (ground)
  • 98fxstc
    98fxstc
    Give us a look at your bike
  • meanmother57
    meanmother57
    if you have power to both terminals in brake light and brake light works cant be bad earth must be a contact problem with  the terminals, could have worn from vibration and only have good contact with brake light circuit, test with wire and bulb to see if it illuminates with wire touching taillight circuit make sure you earth the remote bulb.
  • gigiflip
    gigiflip
    I'll give all suggestions a go before I trundle down to an auto elec and pick their brains. I'll let you know what I find. Here's my old girl. Bob Woods W6 camshaft, cam bearing upgrade, S&S steel breather gear, Screaming Eagle lifters, Screaming Eagle adjustable pushrods. Only ever use Amsoil synthetic oil. To me, this is the best looking bike HD have ever built and this bike will never leave my hands. Ride safe and have a great Christmas everyone.
  • brucefxdl
    brucefxdl
    this might help,how bright is your stop light?.you may have a poor/no earth,in which case the stop light can earth back through the tail light circuit.it will have a weaker glow due to resistance in other globes in the circuit.but as you only have one stop light and in an incomplete circuit stop light switch open]the tail light will not work or only lightly glow and may not be visible through the lense.this is not always the case ...but sometimes.cheers
  • 98fxstc
    98fxstc
    Hi Bill
    I doubt the trip meter  has anything to do with your tailight problem.
    It sounds like the wiring is ok and you have a problem with the bulb fitment in the socket.
    Don't know all the correct terms, but in the base of the socket there is a round piece of insulating material in which are seated the two contacts on the ends of the stop and tailight wires.
    There is a spring behind this which maintains the contact against the base of the bulb.
    Put your finger in the socket and give this piece a push to ensure it can move in and out through its travel range.
    The insulating material has two small tabs at 180° which locate in the sides of the socket.
    Sometimes these can be a bit worn and the contacts will not locate correctly in the base of the socket or they will rotate slightly when the bulb is pushed into place.
    I also found that the orientation of the contacts on the base of the globes can vary a little bit and some seat better than others.
    I have switched to an LED talilight bulb.
    1157 BAY15D LED replacement
    These are much more durable  than the standard globes which suffer a fair bit from the suspension.
  • 98fxstc
    98fxstc
    Don't have too many pictures of my bike
    here is one stock when I first got it
  • 98fxstc
    98fxstc
    here is current after a bit of work
    SE heads and 10.5:1 pistons, SE 57 cam, S&S lifters and Andrews pushrods, 95 HP, 150 rear tyre and black paint
  • gigiflip
    gigiflip
    Meanmother57 ws right. It was a corroded terminal inside the Deutsche connector. There was enough power getting through to register at the terminal but not enough when you put a load on it. Terminals cleaned and problem fixed!
