Pro super tuner leads wanted
  • TC883
    TC883
    Hi Guys, I am after a set of leads to connect the SE Pro Super Tuner to my bike, and to a computer. I need the early EFI leads, with the 4 pin connector (pre 2014 Sportster or any other big Twin) like the picture below. The part number is  32184-08A. All help appreciated, send me a PM if you have a set you want to sell. Cheers, TC
  • keith
    keith
    Let a set of these go to a WA forum regular a few years ago, for a 25 game slik pick lotto and won $34 on the ticket, he might see the post and want to move them on ? Good luck TC.
  • WideglidingNZ
    WideglidingNZ
    Does the dealers not sell them now?
    Not hard to make if you get stuck.
    Or order the TTS ones direct from the states.  Probably quicker, cheaper and exactly the same cabling.
    Should try and borrow a set from someone local to you.
  • TC883
    TC883
    Thanks fo the replies folks. I ended up buying a new set of the leads. Cheers, TC
