Wideglide sissybar does fit FXDLS
  • Ianph
    Ianph
    Just fitted WG sissybar to my 2017 FXDLS. Notched rear support to avoid removing indicator wires etc. No issue as the main support is the front torx bolts, the rear indicator bolts clamp the back completely to frame support. Nothing will move it. Jacked up back end to drop wheel a bit to get indicator bolts out. Probably would have been even easy if I dropped the bottom shock mounts. Two HD shops said it wouldn’t fit. Online pictures say they do and it does!
  • FXDL03
    FXDL03
    7 years ago
    It certainly does fit. I've done it myself also.
    A nice inexpensive pick up from eBay and it with the full length seat, really completes the rear end somewhat.
    Enough bar to attach a bag to in the event of a trip to FNQ :-)
