98 fatboy no ignition, no electrics.
  • beehappier
    beehappier
    Okay, I went for a ride to a market and when I was trying to leave it cranked over and died.
    No ignition, no electrics. No electrical stuff of any kind.
    I checked the fuses under the seat, but they were okay.
    I'm hoping it is just something simple.
    Anyone have any suggestions?
  • brucefxdl
    brucefxdl
    maybe loose battery connection/earth point,or the battery dropped a cell and died.lots of maybe's but you gotta start somewhere.cheers.
  • sam931
    sam931
    This happened to me with a 2009 model FatBob, it was the ""System Relay". left hand side directly below the seat is a cover I could pull off. There is a couple of small black box looking things with spade terminals, don't remember which one, relay cost AUD$16-00. Does your ride have a "System Relay"?
  • Gnoo
    Gnoo
    Did the fuses you checked include the "main" fuse?
    and as said, neg. terminal. (not uncommon on soft tails )
  • Roo Ted
    Roo Ted
    Well written Kiwidave. Couldn't have said it better myself.
