Online: John.R, Stuart
Oil Cooler, anybody have any info on these units.
  • Benno
    Benno
    Have been doing some research on oil coolers, am thinking about joining a group of friends doing a trip to Darwin next year. I found this picture on the US forum, any of you guys know anything about the oil cooler on this Dyna.
    Benno
  • limpn
    limpn
    Mate of mine has one like that fitted to his turboed breakout.. I think he said it was a genuine HD product..
  • Benno
    Benno
    Just found it on the JP Cycles site Limpn, Milwaukee Twin brand.
  • limpn
    limpn
    Awesome his works really well .. turbo created so much more gear he needed to cool the oil down
    Ultima make them aswell have had one on my bikes for years work good  no issues  I think a few of the
    Aftermarket mobs have them in different brands  bet there all out of the same factory though
    You could always try a Oem style slip on oil filter cooler coller  I have one them on my other bike
    The only down fall to them is you have run Oem oil filter as there interference fit  just slip on
    Thay help too. If you do a search there’s a thread on them retroman has done few  temp test
    On the slip on  but I believe the down tube type work better  my 2c
  • OILLEAK2008
    OILLEAK2008
    If you can find one = 'Lockhart'. Function, not looks.
  • Benno
    Benno
    Thanks to everyone for the input, will dig into them a little more.
    cheers Benno
  • Smokey61
    Smokey61
    I've always been of the opinion that they're not needed for the average Harley. Bikes with turbos or towing/carrying heavy loads for example, would benefit from a cooler.
    The oil has an operating temperature range that is optimal and which needs to be maintained. If it's not hot enough, it won't do the job as well.
  • T4
    T4
    Oil filter relocation kit: DK Custom
    Oil Filter: K&P Engineering     www.KandPEngineering.com
  • Odin
    Odin
    DK Customs do one for a Street Glide as well, but where it ends up been relocated does worry me. It ends up below the passenger foot peg, and it may be possible that it could be damaged by a stone, cos I would love one that makes less mess
