TURN SIGNAL MODULE
  • RT711
    RT711
    My wiring was a mess so Im trying to tidy it up.  Im stuck on the turn module.  I have the manual and understand it but there a few things it doesnt tell me.  Does the brown wire have a constant current?  The orange and white does as it comes from the fuzes so that makes sense.  Problem being, that for the right hand lights It uses the brown wire but with a constant current on it the lights are always on (yeah....whoda thunk) I would have thought that the turn switch would provide a pulse to the turn module which in turn would switch power (pulsing to give a on off indicator) to the brown cable but mine has constant power in . Im confused. Any help would be appreciated.  Oh..883 sporty 1995
  • RT711
    RT711
    Yes I filled the blinker fluid tank before I started.  Bulbs are good, wire is fine.  What I am confused about is the power on both the orange/white wire and the brown wire.  The brown wire is power to the right hand indicators.   I would have thought that there would only be power to the indicators once the indicator switch had been pressed, telling the module to send power to the light ( and send it on and off and on etc to make it blink). I have constant power on the brown and I dont think it should have.  Thats my confusion.
  • shadowarrior
    shadowarrior
    Did you find another wire going to the left hand indicators which has constant power? Is your Harley a 1HD (US) model?
