Online:
Hilly
Mid to forward control conversion
Drewborg84
Does anybody know if I can use forwards from a 2016 48 on my 2013 iron?
I understand the master cylinder changed sides from 2014 but not sure if this affects the fittment.
Wobble44
No you can't without changing the brake rod. The lengths are different as is the fitment at the master cylinder, the pre-ABS ones are longer with a rose joint on the end, the ABS models have a shorter rod with just a hole in the end as it fits into a socket on the master cylinder.
Hooters
I have a 2012 48 with forewards if you would like to swap.
