welding advice
  • bloodog
    bloodog
    Trying to braze this bracket on to a 09 rocker
    Speedo, but had a melt down
    Would a mig be the way to go ?
  • steelo
    steelo
    Probably the only way would be to braze weld it. Uses a blow torch and or hot iron to melt (solder) a metal mixture between the two different metals. Have a look on Google
    What metal is the bucket made of ?, looks like some sort of cast aluminium ?
    If so , you'll need a high tech brazing rod for mixed metals.
    The other way is to bolt it together..
  • skirtster
    skirtster
    I would try aluminium mig with a aluminium bracket, you can not weld steel to aluminium
  • steelo
    steelo
    You might have room to drill and pop in some small Aluminium rivets
  • steelo
    steelo
  • Baloffski
    Baloffski
    bd, steelo has a stttuttter this arvoooo.. It happens to all of us!
    His advice is very good, just don"t stutter when poping rivets, is the way I would steer too . (lol)
    Nothing like it , really interacting wit the steel subject, as most unless pro, are shit welders.
    Watching this line, keep going mate, love it, good stuff.
  • Daggs
    Daggs
    Yes, need to know the parent metal type to offer correct advice.
    now I've seen it on my pc not just phone, yes it looks like a crappy alloy. it almost looks like a bin job now!!
    If it is (was) good aluminium and so is the bracket, mig welding or preferably tig welding would be best.
    If no access to that the yes bolting or riveting as already suggested.
    Also as already suggested,  if they are dissimilar materials then bolting or riveting are your only options..
  • steelo
    steelo
    That's easy for you to say say B
    Braze.....and Aluminium in the same sentence do not work.
  • Daggs
    Daggs
    yes you can braze (fusion weld) aluminium, I have done it in the past but not a nice weld...
    tig or mig is the go.
  • bloodog
    bloodog
    I will put the speedo back together and check how much room for bolt / rivet
    The bracket sits up under my risers so nothing will be seen
    Will post a photo when complete
    Thanks for all the help
  • bloodog
    bloodog
    Awsome advice bro
  • Baloffski
    Baloffski
    Those pops are almost as symetrical as that can of VB.Well done bd.
    Sure ain't pretty !!
    Hope there not aluminium rivets.
  • Daggs
    Daggs
    Not pretty at all
    Replace the the rivets with  stainless button head bolts  the rivets won’t last  thay will come loose with time
     with this application  than you will have a dented tank or worse  and nyloc nuts or loctite
  • srd0060
    srd0060
    Aluminum tig would do it but the whole thing needs to be aluminum. Have it all made out of 1.2 or 1.6 tin sheet then you can solder, tig, mig or braze it together, pop rivets are not worth the effort. A failed kinder kid could have made that mess.
