Online: Stuart, speedzter
Australian suppliers for handlebar mounted indicators
  • Kingchops
    Kingchops
    I doubt it, even if there was, you probably couldn't beat the price on ebay.  Price and postage on ebay seems pretty reasonable to me.
  • kaos1369
    kaos1369
    Your local Harley Shop should have them on the shelf mate, they are an authorised dealer for them.
    Are they legal?
  • SRV72
    SRV72
    I'm pretty sure Browns Industries sells them. Check out their face book page mate
  • Benno
    Benno
    I got them from Brown Industries, they have two different sizes, good guys to deal with also.
    Heads up Easy R will have them very soon at a third of the price
  • TJU
    TJU
    As mentioned above ... KPR Industries out of Brisbane ... They do the rears as well , bolts straight onto the Fender Struts , really gives the bike a clean look ... Both front and rears are smaller in reality compared to pictures , but look fantastic .
    Can't testify to the legal side of things but was pulled over twice for the obligatory speeding ticket and didn't get pinged either time ... Maybe I got lucky ... Wish I could say the same about the Speeding tickets .
    With a bit of luck if Walka is right and the quality is as good then the ones from EasyR at a third of the price might be the way to go as the KPR units are not the cheapest things around .
  • ToeCutter21
    ToeCutter21
    Installation question:-
    Parts have arrived. Looks like I'll have to disassemble bar mounted units to connect wires. Is there going to be some trick to this in terms of removing the whole thing that I don't need to do? Will the wiring inside be a solder job of simple nuts?
  • kaos1369
    kaos1369
    Cut your old ones off near the cowl, get under the tank and find the indicator wires, piss off the cable restraints and pull out as much as possible. Solder the new ones together, watch out as the new wires are thinner, use heat shrink and keep it neat, once together, you can push as much wire back into the bars as possible. Get back under the tank and try to nip them up if possible.
    Make sure nothing snags, just get stuck into it, you will be right. The lights on the dash will blink faster but the actual front and rear blinker will flash at the correct rate. make sure you grab onto the mirror when you tighten them up otherwise the fucken thing moves all over the place. I fiitted mine to my Breakout with no dramas at all. Have fun
  • limpn
    limpn
    Also got mine from browns nearly a yr ago .. easy as just take old ones off and they just fitted perfectly.. make sure you got the right ones for your model
  • mrjessehlee
    mrjessehlee
    7 years ago
    wow you might have just saved me a 100 bucks.
    one thing.. I called up the guy (nice guy), and he hasn't sold one for 2018 softail street bob medel yet and wasn't 100% sure if the one designed for old street bob will fit on 18 models.
    Does anyone by any chance have two models next to each other?? I know it's a long shot..
    Thanks guys.!
  • Muzza Wa
    Muzza Wa
    7 years ago
    I’m liking these lots......
  • Superlow 11
    Superlow 11
    7 years ago
    I just fitted some today along with t-bars and chrome switch housing,the indicators set me back about $260 from MCA in Dandenong
  • mrjessehlee
    mrjessehlee
    7 years ago
    Based on my convo with Easy R, they will get them in stock soon and will be sold for around $300. For this price I'd recommend Heinz motorcycle from Germany, these guys make their own lights with amazing fit and finish.
    Brown Industries (Aussie based) sell a set as well for 200 bucks, Chinese made with thinnest electric wire you will see in your life.
    Not the best fit but it works on my 2018 street bob.
    I wasn't super duper thrilled about the fitment as I was expecting it to fit like a glove, especially this lights being $100 bucks a pop.
    ended up using the washer but made it work in the end. Also the right side has this stupid offset. (see photo)
    Based on my research, ALL of these lights (regardless of brand) will have normal rate of blink on the led lights itself but the dash light will blink at faster rate, FYI.
    Just thought I'd share my experience here so you dont get caught out if you are pedantic like myself. Otherwise happy with how it turned out.
  • Benno
    Benno
    7 years ago
    Dunno what that link is, probably one of those pop up ads, your local Indy should have one of those equilizers to suit your model, if you need one.
  • TJU
    TJU
    7 years ago
    My understanding is that you have to use Load Equilizer with these Led Indicators so it dosent interfear with ECM singles and also Flashes normally ... You don`t want to give Officer Plod any excuse to pull you over and ask why are your blinkers Flashing either to slow or to fast .
  • mrjessehlee
    mrjessehlee
    7 years ago
    Yeah true, my LED lights (shown in photos above) blinks at the normal factory rate and happy to report no alarm lights either.
  • Benno
    Benno
    7 years ago
    Mine was the same, blinkers flashed at normal rate, but the dash indicators were not constant, if it wasn't for the alarm coming on I would have put up with the dash lights.
    I just didn't want to not know if the alarm was because of the indicators or some other issue, I guess different models/years will vary whether you need the load equalizer or not.
  • Ferrett62
    Ferrett62
    7 years ago
    Just wondering, when fitting these how do you do the wiring on the bars? Do you cut and solder or run new wire through the bars.
