Online: John.R
17 Street glide rear indicator bar, smoked lens??
  • matho1961
    matho1961
    I have a 2017 Street Glide with the typical rear LED light-bar with amber lenses (red running, red braking, amber blinkers). The amber lenses sticks out like dogs balls with my denim black. The last 3 days, I have looked everywhere online for an exact light-bar but with smoked lenses and nobody seems to make it. Does anyone know who makes a light-bar with smoked lenses. But must have the same LED type system. Thanks.
    Easiest way is to get yourself this stuff to spray on. Light coat on one at a time so it's not too dark. Did this to my road glide and it worked well.
    http://www.supercheapauto.com.au/Product/VHT-Aerosol-Paint-Nite-Shades-Black-283g/7790
  • steelo
    steelo
    Good idea FB. I was thinking maybe the CVO models might have something.
    Yep. Used masking tape and newspaper so no spray went anywhere but on the lenses. Just spray light and let dry, and repeat until happy
    No dramas. Post up a pic when you're done. Good luck.
