Can anyone Identify this bobbed out bike?
  • mrjessehlee
    mrjessehlee
    Hi all,
    Can anyone be able to tell what the base model of this bike is? or know anything about the bike? the owner, the build, history, web page link, photo of the other side etc?
    All I can tell is it's pre 2017 softail family so far..
    I am looking to build one similar to this and contemplating about getting  2018 street bob.
    Appreciate your time and advice in advance.
  • Kingchops
    Kingchops
    Nice lines, and good to see the use of a Softail frame instead of those impractical rigid frames.  Try doing a Google image search on it.
  • steelo
    steelo
    From image search
    Harley Davidson Springer Softail with Sportster gas tank, solo seat.
  • mrjessehlee
    mrjessehlee
    lol thanks for that, I got the image from google with no luck at finding further info on it.
  • mrjessehlee
    mrjessehlee
    Had a closer look at the swingarms of these two bikes.. hm.. its great the 18 model has that hardtail look but the bottom arm has this dog leg in it.. shit!
  • Gnoo
    Gnoo
     It's pre 08.
  • Big Steve
    Big Steve
    Lines and proportions look very similar to what Zero Engineering builds (Google them) except all their frames are rigids.
  • steelo
    steelo
    This frame just came up on Gumtree 2 hours ago. Could be a good starter for a project for you or someone on the forum. As long as frame is legit Harley and not a write off
    It’s not a Oem frame  aftermarket evo and less it has a mso it’s  scrap  or a big
    Stuff around to to get it legit
    It’s a EVO softail not twin Cam
