Royal Enfield bullet 500
Tracy Hanson
Hi all. A very frustrating issue, with my RE Bullet 500. Battery is tested and fully charged and starts the bike well, but after running it, even just idling for a few minutes when you turn off the ignition and try to restart the bike "nothing". No horn, no lights no "N" for neutral indicator , nothing. No ticking sounds, just simply dead. Each time i have checked the fuses all ok, wiring looking good, connections to battery and frame excellent. Battery good, even slipped a brand new one in and same issue, motor starts, turn it off and nothing. Wont start for few hours or more after ignition has been turned off. Any clues???
Sure....try a Royal Enfield site
FXDF08
Try ringing Motomax, Osborne Park, WA. They’ll help you with some suggestions over the phone. Other than that, try another site perhaps?
steelo
Here's a
site
Quite a number of people with similar issues. Didn't spend much time looking for a solution though
John.R
Money is on stator/regulator.
Anytime i read "i even bought a new battery and its doing the same " confirms it lol.
Charge the new battery. Start your bike and put a multi meter on your battery.
Less then 13v and u need to check ur stator and reg.
