Back brake light switch
Arron
The back brake light switch on my 2013 Street Bob seems to be stuck on.
It looks like an easy enough job to change and the switch (72026-08A) is about $22 -$44 on eBay but it's an ABS equipped bike and the switch doubles as the banjo bolt for the brake line and would need to be bled afterwords.
Does anyone know if this can be done without taking it to the dealers ?
AJ56
Are you sure it is the rear brake switch?
Drac
I had to replace mine a while ago.
Same reason, light staying on.
No prob bleeding with abs.
Have also changed front and rear master cylinders and brake lines.
Never had any issue bleeding.
Arron
Got it sorted , the new switch from Perth HD was $14.70 and was all good on the short test ride.
