Online: Retroman
Painting primary cover
  • GTEEZ
    GTEEZ
    What are peoples experience with the different options to black out the primary cover? Spray paint 2 pak, powder coating, HD texture paint (or other brands) in a rattle can. I had my fork legs powder coated but it chips easily. Could also have been a dodgy job but they were blasted before being coated.
    Cheers.
    I’ve done both powder coated and painted on different bikes , never had and issues , I’ve always used Harley Paint if I’m painting them
  • GTEEZ
    GTEEZ
    I think I will try the HD texture paint with an etch primer under it. If I stuff it up it will be easier to remove than powder coating.
