Online: Soapbox2627, John.R
Another LED light conversion (Daymaker style) on my 2014 Sportster XL1200C
  • shajar
    shajar
    Hey, just thought I'd share some pics of my new Daymaker headlight I picked up off eBay for $94 delivered. Seems bloody bright compared with the OEM, hopefully not shining in peoples eyes,  yet to see as haven't riden with it yet, I'm sure I'll get flashed if its not adjusted correctly.
    Swap job was easy, I had to cut and use the OEM rubber ring that had 4 little stabilizing extensions (like spacers), it only just stretched over the rear of the LED heat sink when trying to fit, without it the lens just slopped around with about 3-5mm movement. Its a shame it wasn't a glass lens, I'd be happy to pay another $50 ontop for a glass lens if it was available.
    Original OEM headlight on low beam, sorry my phone takes crap low light pics
    Original OEM headlight on high beam, again sorry about dodgy image
    Daymaker LED on low beam - see the image getting better...
    Daymaker LED on high beam
    What the bike now looks like with black LED headlight
