Deal pop
Deal pop
mandingo
Hi put some big shot staggereds and a screaming eagle heavey breather a/c stage one setup on my 103 fat bob , im using the sepst tuner anyways got a dyno from a indy in my area and even with a dyno run that cost me $400 the friggen thing pops bigtime on decel, the bike runs fine but is popping even between gear changes and when ya back off,I know there not everyones choice of pipe,and are basically a straight through setup even with the baffles, has anyone dialed out this problem properly with the sespt tuner or have a map they wouldnt mind sharing if not its going back to him to sort out,cheers
No air leaks in the system....
Daggs
Big shots shouldn't be too bad to tune, they at least have the the power chamber don't they?
I had short shots mate and they are even worse but my dyno tuner got rid of any deceleration pop whatsoever, just a bit of gurgling on a steep downhill run with no throttle but no pop.
So yes it should be able to be tuned out.
By the way, that price you paid is probably at the bottom end of what a decent tuner might charge so don't know but just maybe he isn't quite up with it...
PM me your email address
Tell me the model/year/mods
Daggs
Good result, great to see the forum working well, well done Retroman
