Springer Front End - HD v Other
  • CrackerJack
    CrackerJack
    Howdy all,
    I know that there is a million different aftermarket springer front-ends out there of varying qualities.
    Being new to this scene I am doing a lot of reading for a Bobber project I am working on and I am hearing that not many if any of the aftermarket front-ends out there stand up to the quality and ride of HD's OEM versions. I am keen to hear from anyone who has used aftermarket springer front ends on bikes and what their experiences are?
    Thanks in advance
    Jack
  • brash
    brash
    Led Sled and Paughco make good ones.
    Lots run the DNA/Attitude/etc springers made in China with varying levels of success. There has been some failures but that can go for any fork when given a big enough hit. The problem with the cheap springers is the terrible ride and squeaks/rattles they give.
    As above, there are 2 types of HD springer, look for the straight leg. The Offset one can work well but depends on the rake of the frame in the neck. Can give a real odd look once assembled plus some interesting handling.
    My recommendation is to spend a bit more, look at some of the US manufacturers who do custom lengths depending on your frame and look. They can do wide/narrow/brakes you name it.
  • CrackerJack
    CrackerJack
    thanks for the feedback Gents, gives me some homework to do.... cheers
