Online: baldy1450, Rextheute2022
Revalve Specs for Ohlins FKC-101 carts
  • Nutty
    Nutty
    Compression leg specs arrived at FYI. Pre-Rushmore (FLHX) . Reb leg is stock set-up.
    21
    20x3
    12 crossover
    20
    18
    16
    14
    13
    12 pivot.
    All shims 0.1mm, oil 16CST at 130mm, cart pre-load 17mm, top-bolt pre-load 12mm. Springs are 1.1kg/mm.
    Rides very nice, comfortable over potholes and road repairs, perfect amount of dive under brakes, good bottoming resistance. Will also suit fast/heavy guys on FLHRs.
