Online: beaglebasher
07 Streetbob tacho
  • shfunky
    shfunky
    Hi everyone, been trying to hook up a tacho to my 07 Streetbob without much success.
    I have the light sorted but no signal, tried the LG/V on the speedo loom with no result,
    I have seen the "shareaproject" pictorial but the ecm plug in that has no wires going to
    pin 1,2 or 3 and they wire into pin 3, on my bob pin 1,2 and 3 all have black wires going
    in them? My manual doesn't show any wires to them at all. Anyone had the same problem?
  • Gnoo
    Gnoo
    Yep pin 3 is where ya want t be.
    I ( me that is) would cut black wire and join (green?) wire from tacho to pin end of it.
  • shfunky
    shfunky
    Thanks Gnoo, might try that, I wonder where that black wire goes to , no mention of it in the wiring diagrams
  • Gnoo
    Gnoo
    Black is usually ground, see if you can follow it and confirm. don't understand why tacho output would be earthed though.
    Have you had bike from new, previous owner could have run a tacho and only had black wire ?
  • shfunky
    shfunky
    Had the bike since new, so those wires are all stock, that's what I can't understand, as you say black is usually an earth, the wiring diagram shows pin 3 on the ecu plug as 'tacho ouput' but no actual wire coming out from it for a Streetbob. It also shows pin 1 as unused but as I said all three pins (1/2/3) have black wires coming out? Here is the  link to what it should look like
     http://www.shareaproject.com/pages/projectThumbs,p,173,display,9,limit,9,offset,36,00.html#navPrev
    Gibo
  • Gnoo
    Gnoo
    Done mine (07 fxst) some years ago, pin 3 was vacant,
    would have thought dyna would be the same, seems not.
    Just a thought : mine is an 06 year of manufacture,
    if yours is an 07 year of manufacture it may have the newer wiring on it.
    Have a look inside headlight shell and see if you have a PINK wire in there.
  • shfunky
    shfunky
    Hey Gnoo, yes I do have a pink wire in the headlight, but I don't use it as I fitted a Fatboy headlight several years ago and didn't need it. What's the significance?
  • Gnoo
    Gnoo
    Don't know what the significance is,,, but,,,
    I'd (me that is) join the tacho wire ( that's meant for pin #3) to it
    and see if tacho works. I'm think'n it will.
  • shfunky
    shfunky
    Hi Gnoo, tried it mate but no success, I am at a loss, the wiring diagram doesn't even show a pink wire to the headlight? How did you know there might be one there? The ecm plug wires don't match anything like the wiring diagram either, makes it hard. Thanks for your help buddy.
  • Gnoo
    Gnoo
    I think 08 up you tap into the pink for tacho.( I'm still a bit confused from the 70's )
    All I can suggest is go back to plan one and cut black coming from
    pin3, if things go t shit, join it back up again.
  • shfunky
    shfunky
    Thanks Gnoo, my diagrams are the same, anyway I did what you suggested and went back to plan 1 and joined the tacho to pin 3 on the ecu plug, I just cut the black wire and connected in the tacho and shabam! it worked. F knows why they decided to wire in pin 3  when 07 Streetbobs don't have tacho's. It would have been nice to know where that black wire went too, m ight have made it easier. Anyway now to tidy everything up, for anyone out there with an 07 Streetbob or come across their ecu plug with pin 3 already taken, just wire it up with an inline splice or such. Thanks again Gnoo for taking the time to help mate.
  • Gnoo
    Gnoo
    All good mate, glad ya sorted.
