Online: Soapbox2627, John.R
160 RWHP Emu Chaser anyone?
  • LOFTYBOB
    LOFTYBOB
    Say hello to my new Adventure bike.
    2017 Triumph Explorer XCA, these come out with 137 RWHP stock, but Mr Neville Lush Racing gets 160 RWHP out of them easy.
    From the brochure ;
    Built for all terrain, the Tiger Explorer XCA is the ultimate go anywhere, do anything transcontinental motorcycle. The Explorer XCA packs immense power and linear torque from its signature 1215cc triple engine and is optimised for all terrain with spoked wheels for tubeless tyres, ABS, Traction control and, Brembo monobloc 4-piston radial callipers at the front, and a single 282mm disc, 2-piston sliding brake at the rear. Triumph's electronically controlled semi-active suspension system (TSAS) continuously adjusts the suspension settings as you ride, delivering the best control, comfort and riding experience on any surface.
    Max power 139 PS/137 Bhp (102 kW) @ 9,300 rpm
    Max Torque EC 123 Nm @ 6,200 rpm
    Brakes front Twin 305 mm floating discs, radially mounted monobloc Brembo calipers, 4-piston, switchable ABS
    Brakes rear Single 282mm disc, Nissin 2 piston sliding caliper, switchable ABS
    Front Suspension WP 48mm upside down forks, electronically adjustable damping, 190mm travel.
    Rear Suspension WP monoshock, electronically adjustable semi active damping, 193mm wheel travel. Automatic preload adjustment.
    Instrument pack:- analogue tachometer, fixed segment LCD display & multifunction dot matrix LCD display. Fixed segment LCD display: speedometer, fuel gauge, gear position indicator, service indicator, clock, ambient air temperature, coolant temperature, cruise control status & set speed. Multifunction DOT matrix LCD display: five Riding Modes (Road, Rain, Off-Road, Sport, Rider), windscreen adjustment, TSAS setting, Trip computer (journey distance, journey time, average fuel consumption, average speed), motorcycle information (odometer, range-to-empty, instantaneous fuel consumption, TPMS), settings menu, heated grips status, heated seat status.
    I have ridden a mates tuned Tiger, and it is a weapon.
    Heated seats are a bit gay, but no use taking them off lol.
  • steelo
    steelo
    Looks great LB. Did it replace the Tenere or has that been gone for a while? Love to have one myself. Cheers
  • Baloffski
    Baloffski
    Opens a whole new meaning to the word "Chook Chaser". Bloody good shit, Lofty.
    What does Lushy do to get the 160 from them....
  • Big Steve
    Big Steve
    Nice bike
    I'm guessing she doesn't need a new set of front disks with every set of pads (like my Beemer does)...
  • bloodog
    bloodog
    Love her lofty
    Come up to Alice from Port Augusta the back way through Dalhousie hot water Springs then Fink track into Alice , you can stay at my place
