Cleaning Bike
Cleaning Bike
Humbug
Hello all,
Went to clean the bike and found(after I had smeared it around) what looks like chewing gum on the front guard. Have never had this problem before and have no idea what to use to safely remove it. Any tips?
Humbug
Paz141
Either of these 2 will work well
keith
Eucalyptus Oil also great tar remover.
Well i learnt something today
Humbug
Thanks for the reply's gents. Do appreciate your help.
Humbug
Humbug
Ok, tried the Eucalyptus Oil and it worked a treat,easy as it came straight off.
Thanks Keith and to everyone else for your ideas.
Regards
Humbug
Daggs
Citrus based cleaner possibly too will do it..
