Music
  • Steve L
    Steve L
    I have a 2012 SG and always listen to music when I ride. I don't like having the phone plugged into the unit via a cable, is there any way around this other than updating the stereo. I have tried a Bluetooth device that plugged into the mp3 inlet but it constantly kept cutting out.
    Would a 4.3 stereo froma 14 model work without any problems.
  • Steve L
    Steve L
    thanks Paul, hoping to get away from wires but hiding it might be the next best way.
  • Steve L
    Steve L
    Cheers Paul
  • DarkAz
    DarkAz
    Not sure about the '12 SGs, but I put the music in mp3 format onto a USB and leave that plugged into the unit on my '14 so I don't have to rely on the phone for music - works a treat
  • steelo
    steelo
    No need to convert the music to MP3 for the 14+. If you have itunes, simply select the songs from your play list and drag them over to the USB. There's a thread here somewhere.
    Sorry can't help you with the 14- bikes.
    A little USB hub (needs to be small) allows you to use a USB drive for the tunes and a small cable for the phone (charging / music) in the bike phone glovebox
