Online: beaglebasher
O ring
  • Blackbob
    Blackbob
    The o ring on the drain plug has shit itself!! Probably  a stupid question but will any o ring do or are they treated for heat?
    Silicon vs. rubber orings would be my only thought.
  • Retroman
    -0-13 Viton O rings from your local gas/hydraulic/plumbing/bearing joint
    Buy them in "bulk" , I get 100 at a time. Works out a fraction of the cost of "genuine" HD ones from your Harley dealer , they charge $1.35 a piece !
  • OILLEAK2008
    OILLEAK2008
    I use ones from a $2.99 set from a junk shop. Just a new one every time.
  • FONTANA302
    FONTANA302
    O-Rings (engine case, tranny pan and primary case):
    Soft Buna-N O-Ring ID 0.426" Thickness 0.070” OD 0.566"
    #AS568A Dash Number 013.
  • Daggs
    Daggs
    The o-ring in the fuel quick disconnect on the fuel tank is also the same size as the drain plug o-rings
  • brucefxdl
    brucefxdl
    john deere have an equivalent o ring,dont know if the price compares but handy for me [ work as tech at a dealer ].have the number some where.cheers
  • Blackbob
    Blackbob
    It's the oil drain plug
    I'll check with our local ag suppliers see if they have the john Deere one otherwise it's a 5 hour round trip to the dealer
  • Daggs
    Daggs
    Any bearing store or industrial store should stock them
  • FONTANA302
    FONTANA302
    The fuel line O-rings are not the same as the drain plug O-rings.  The fuel line O-rings are:
    Fuel Line Coupling O-Rings:
    Large - ID 0.414" Thickness 0.072" OD 0.558" fits 5/16” tube.
    AS568A Dash Number 905 – Parker #3-905; John Deere #R26286.
    Small - ID 0.299" Thickness 0.103” OD 0.505" #AS568A Dash Number 109
  • brucefxdl
    brucefxdl
    got curious..went and measured the factory drain plug o ring[ fxdl '07],that close to the same size as jd o ring its not worth measuring.jd o ring suits fuel connectionas well.
  • Baloffski
    Baloffski
    Blokes are we getting a little pedantic here. What fits and don"t leak is the go.seriously.
  • Daggs
    Daggs
    In my case for a 2008 dyna it is the same size or close enough to the same size to do the job perfectly. 0.002’ difference on the thickness ain’t going to matter. That o-ring has been in place on my bike for about 3 years and is doing its job fine. They are o-rings, they give a bit..
  • Blackbob
    Blackbob
    I picked one up today from the ag dealer ??
    Oils in and the bikes ready for a week in SA
    I'll call into Edenhope next Saturday for lunch hope to see some there
    Thanks again for the replies
