Slamtail or Shotgun ???
  • Joeli22
    Joeli22
    On the home stretch finishing my vicla softail.
    Any advice appreciated on wether to go slamtail hydraulic or shotgun air ride for the rear suspension.
    Currently running OEM shocks with a 2" lowering pin/bolt fitted. Ridding at 2" max drop ( quite a hard ride I'm sure you will agree)
    I want to:
    Get a more comfortable ride
    Adjustable
    Be able to slam the bike to the ground when parked up.
    All the US forums are saturated with pro shotgun people and that's fine - Slamtail being Australian; I'm sure very few in the states use it.
    Just want some real world advice it anyone has experience of both systems.
    Thanks j.
  • Paz141
    Paz141
    I havent had experience with the shotgun kit but i read the instructions the other day and it looked so much easier to install if you are doing it yourself.
    A mate recently had a slamtail fitted to his breakout, rides nice raised or lowerd. He rides around with it slammed and it still has a quality rixe
  • Big Steve
    Big Steve
    With the shotgun I always liked that you can add air to stiffen the shotgun at any height
    Not sure if the slam tail works the same.
    JD has a pretty decent following of customers in the US and abroad.
  • ralphski
    ralphski
    have Shotguns on my Softail.
    can't say a bad word about JD and Jess, excellent to deal with.
    as for the shock, worth every $$$$.
    would highly recommend them.
  • DR
    DR
    +1 for Shotgun Shocks, best mod I have done
  • Spero
    Spero
    I've got a slamtail kit on my 2011 FXST & fucking love it! 2 1/2" of suspension travel & the ride, feel & comfort compared to standard is unreal! Ken was super helpful when I purchased the kit & spent about 10 minutes on the phone going over how to instal the kit, although I ended up getting a local bike mechanic to fit it as I was days out from my wedding & ran out of time to instal it, it took him 3 hours to instal & he said it was very easy to instal & was really impressed with the whole unit. All up the unit was around $2150 to purchase including the spring pre-load adjuster kit which to date I haven't used & to be honest I don't think you need unless you're planning on doing lots of two up riding. The best thing about this unit is it's 100% Australian designed & manufactured!!
    Cheers, Spero..
