Online:
John.R
V&H Fuelpak
V&H Fuelpak
Kustomtown
I have a Vance & Hines Fuelpak I'm looking to sell but I can't find any part number on it to give buyers some details.
I THINK it cam off my 2011 Road King but it may have come off my 2009 Road King too....memory is fucked, can't remember.
All I can remember is that it's easy to program.
Anyone know how I can tell which model it is? It does look like the v61019
Kustomtown
Ha, you're confused?
My memory is fucked.
Just trying to work out what model Fuelpak I have....there's no model number on it.
shadowarrior
I don't think you another bike can use your V&H FP. They get married to the first bike's vin and stays locked, don't think there's any other way to unlock it.
How many motorcycles can I tune with my FP3?
Answer: Each bike you tune will require a different FP3. The FP3 will “marry” to your VIN when you flash a map to it the first time. After that, the FP3 will not be able to flash any other bike. You can still use it to read diagnostic trouble codes or display live data on any CAN bus equipped Harley.
http://fuelpak.vanceandhines.com/faq.html
https://www.hdforums.com/forum/the-dyno-room/966760-warning-to-potential-buyers-fuelpak-fp3-forever-married.html
mrjessehlee
used fuel pack wont work on any other bike!
Mr.Mow
Can confirm FP3 is not transferable, have had to buy one for each bike, contacted V&H and they told me they can’t be reflashed.
Kingchops
The OP seems to be talking about an older Fuelpak which can be used on another bike as it's an add-on unit. The newer FP3 cannot be used on another bike as it's a removable tuner not an add-on.
Older style Fuelpak which
can
be re-used:
Newer FP3 which
can't
be re-used:
