Custom Dynamics LED Turn Signals
Lowrider762
Hi I purchased a set of Custom Dynamics LED Turn Signals Inserts which work well. However the Aussie Harleys don't have active running lights like in the US. Meaning the front indicators stay on all the time and flash when used. Custom Dynamics have a white ring which illuminates on the front turn signals and turns off once the blinker is activated. I have 1157 sockets and the white rings do not illuminate, does anyone know how to activate power to the turns signals for the white rings to work as they do in US models? Fitted to a 2014 Lowrider.
Lowrider762
I think you are right regarding the wiring, I thought it strange that it has a duel filament bulb without function. I think I will have to lift the tank and check the wiring to the plugs. As it needs the 3 wires ground, power, turn signal. I may need to get them rewired.
Lowrider762
Also the front turn signal housing is 1157 and rear 1156 single filament.
