Online: beaglebasher
Woods TW-999-6 Cams
  • SLIM_DUSTY
    SLIM_DUSTY
    i'm ordering the Fuel Moto 110 kit soon and these cams are the option they seem to go with. will be running 10.75:1 or 11:1 comp with the set up plus head work ect. My question is has any on here had any expierance with them. Thoughts ?
  • brash
    brash
    All of Bobby woods stuff is good. I'm looking at the Tw-777 myself for a stock compression se110.
    You are onto a good thing with fuel Moto. They have plenty of runs on the board with their kits and great customer service. Will you be putting it together yourself or someone installing for you?
    Agree Jamie hooked me up with a base tune for my power vision even though i did not but from them
  • SLIM_DUSTY
    SLIM_DUSTY
    I'll will be getting someone to put it together for me. Bought the TB last week say I'll be getting the kit next pay with all the overtime I'm going at the moment.
  • SLIM_DUSTY
    SLIM_DUSTY
    So has anyone used these cams? It says on fuel moto comes on early but on woods website it says 3000rpm. That's not really that early.
  • brash
    brash
    depends on a heap of factors there. Fuel moto has heaps of dyno charts of 107 kits in various combos, find the one closest to your proposed build and see where the torque builds.
    Knowing woods cams, you will have 100+ft lb at 2500rpm with pretty much all of them so that's adequate.
    With your proposed build, 110ci with heads and 11:1 comp I don't think torque will be a problem. But remember the exhaust will make or break that combo.
    This is a 107 build, yours in theory could make 3-4% more power/tq
    I will almost guarantee you wont make the same numbers as Fuel Moto show.
    Those Cams have a very tight LSA from memory , and will be fussy on head flow and pipe choice.
    The headwork/pipe will make or brake the outcome.
    What bike and what heads ?
    If it were me, I would choose another Cam that has a more consistent outcome.
