Fob Question
    Hi,
    I have a spare fob that came with my 2009 Sporty that I have never used, but wanted to make sure that it operates just in case I ever need it.
    I have changed the battery yet it still does not seem to cancel the alarm.
    Is there a sequence or something I have to go through or do I have to take it to a dealer to get fixed?
  • Retroman
    Each bike can only have 2 fobs assigned to them at any one time.
    New/replacement fobs can only be coded to the bike using the dealer digitech , takes 20 minutes or so. Fob plus coding around $100
    So if you "lose" an original one , then get the dealer to "code" a new fob to the bike , then find the original , the "lost" original will not work.
    Double check the new fob battery you have is good , AND that it's in the right way round
  • Ken in Cairns
    Ken in Cairns
    Also check that the little prongs the battery press into are bent up enough to make a good contact, I had issues because of that with one of my fobs.
    Thanks guys, I'll check these suggestions out.
