Online:
Hilly
compatibale
compatibale
666
asking for a mate will std 110 barrels and pistons fit on a 103
Steve L
He was asking for me, the barrels are from a new Lowrider S. Will the SE heads I bought fit the barrels.
Steve L
thanks very much mate, thinking now I might just go 10 thou over on the 103's and run Keith Black pistons to keep the cost down a bit. Been talking to a few people and they reckon with keeping it 103 with the 585 cams and the SE heads I should still get around 105 to 110 hp.
Daggs
yeah you should, depending on where you set the compression.
When I had 585's in my 106 I still had stock heads so comp was at 10.0:1 and my hp was 98, torque was 115 ft/lbs
585's are said to be at their best at 10.8:1, I personally would be aiming for 10.4 to 10.5
Steve L
thanks and yeah pretty much what I thought. Still thinking about 107 if I can find a good place local who can bore my cylinders.
