Winpv software question
  • Drac
    Drac
    Does anyone know why the Winpv software has tick boxes down the left side and none are ticked when a map is loaded.
    Is there any need to tick them when making changes.
    Cheers Drac
  • brash
    brash
    Don't need to tick anything, just make the change and save.
  • robnicko
    robnicko
    When a map is loaded you are viewing the root of the map file, upon selecting an area to view / modify (eg Tune Info and then ticking description) the field selected will display the parameters on the right hand side window
    therefore, only select / tick an option to view and or edit
  • Drac
    Drac
    Thanks mate
