Online: Stuart
which cams
  • Steve L
    Steve L
    I just bought these heads for my standard 103,
    Screamin Eagle Pro CNC Ported Factory Heads
    The bike has a full Vance and Hines exhaust and a heavy breather and sert.
    Just wondering what would be a good set of cams to use with them. I would like some more low and mid range usable power.
  • Illustrated_Man
    Illustrated_Man
    SE259E cams work nicely with a 103 with head work.
  • Steve L
    Steve L
    so not much under, thinking maybe Andrews 57's
    A lot depends on the compression.
    Are you just bolting the heads on as is with flat top pistons ?
    The 259's can hit earlier in the right setup, at around 10.5 - 10.8 .
    As a bolt in, stock comp 103, the 57's will do pretty well in the range you want them to work, and are cheap and easy to get hold of.
  • chriso
    chriso
    Yeah good replys, I had 259es in my 103 with these heads, 10.5 comp. came on hard around 3200 rpms and was a joy to ride.
    Got em sitting in the shed if ya want them?
  • Steve L
    Steve L
    I got some S & S 585 cams for the right price,  thanks everyone
    They are more mid/top end biased.
    What compression are you planning on ? (they will still want 10.5 - 10.7)
  • Ken in Cairns
    Ken in Cairns
    At what Comp ratio do you start having pinging issues with standard 95 Ron pump petrol.
    Over 10.5 :1 ?
    I used to know all this shit when I was a young punter :(
    Shit I hate getting old LOL
  • Daggs
    Daggs
    S&S 585's are an awesome cam but yes more mid to top end as speedster has stated
