Online: John.R, baldy1450
workshop lift suit sportster
  • 009jim
    009jim
    Gents, I've been researching for a while now for a workshop lift for my sportster. I need a device to lift it a hold it securely level for jobs such as changing the transmission oil.
    Findings thus far are that the Harbour Freight model seems to be well recommended. This one........... https://www.youtube.com/watch?v=6Vrypyz1eTg
    Then there is this similar one...............https://www.youtube.com/watch?v=ns3FE2W2qd0
    Note how these both have loops for connecting tie-down stays which I want.
    I want to buy one of these or something like it from an Australian supplier. Can anyone make a suggestion please? Feel free to suggest alternatives if you they have worked well for you.
  • Neale
    Neale
  • Neale
    Neale
    Becker Enterprises, in Melbourne, made in Australia. This is my second one and I like 'em.
  • Ferrett62
    Ferrett62
    I know supercheap auto sel an atv jack similar to the first clip, haven't tried it and can't remember the price but I know it wasn't too expensive and I don't know if it was their brand or another just remember seeing it while I was looking for something else.
  • Nutty
    Nutty
    IB bikelifts in Gateshead NSW. $399. Best one I've used/seen, Aussie design as well. They have a website. Lifts a dresser without raising a sweat.
    Re IB bike lifts I cant see on their Web site where their lifts are made but their google ad says made in Australia
  • fizzicist
    fizzicist
    I've been using the orange repco special for the last 3 years. It's served me well.
    I've had a good look at all the welds on it and they are average but they are holding up.
     No leak of the bottle jack so far.
    Only complaint i have is the rubber on top of each arm isn't held on the best.
  • Benno
    Benno
    Quote
    I have the same Repco special, same issue with the rubber on each arm also, no other problems with it. What are you using to stick the rubber back on, I have thought about leaving it off, but I have to use a lift adaptor kit for the WG.
  • 009jim
    009jim
    Has anybody used the Autobarn one? Was it alright?
  • Sprocket
    Sprocket
    I am a but undecided whether to sell my Becker stand soon. I pulled off the wheels to experiment with other size wheels and they have gone missing (thanks kids). I was trying to get the height just right to enable cleaning both wheels easily. I'll have to get some new wheels first though.
    I am now using a cheap one like this style which so far works ok. Still best to have a second person to help.
    I might invest later in a small scissor jack like this
  • 009jim
    009jim
    hey that pallet-jack is a novel approach
  • weedoman
    weedoman
    Seen the Kendon ones? Check out this thread and sing out if you're interested:
    https://www.hdforums.com.au/Thread/671223/1
  • 009jim
    009jim
    Just bought this one. Stay tuned for report after use when I change my transmission oil.
    look's good to me Jim . I would be interested in one, so look forward to your update.
    I thought I would mention , I have used bike stands on my own on Harley big twins no issues. I would first line up the stand beside your bike, get on your knee's, so you can get a good view where it is going under the bike and when it will support both sides. you get hold of one handle bar grip with one hand, get bike straight up and off jiffy stand, takes very little effort to keep a bike up when you have hold on one handle bar grip. then push the stand under it with the other hand. once under and how you want it, still holding the handle bar, stand up and raise stand so it is supporting the bike but not lifting it, then go around check it is all stable , then take hold of handle bar grip again and slowly raise the bike checking its rock solid . I could not see a need to tye it down , unless you have to do some very man handling work to the bike that you will be pushing and pulling , like say rear wheel removal. and then take great care as the weight distribution will change dramatically when wheel comes off.
  • 009jim
    009jim
    Better give me a couple weeks to respond. I kinda hurt my back lifting that sucker out of the car. LOL. I gotta assemble it then too.
    Just be careful when you first do it.  Some jacks to need the kit (or some wood) to clear the pipes and to keep everything level.  Don't start "jacking" till you know it's stable and not pressing on anything you don't want pressed on - and even then be careful.   And be just as careful when you lower it.  Some jack releases are touching so they either release too fast or they're jerky.  I usually keep one hand on the handlebar grip when bringing it down.
  • Neale
    Neale
    I don't know why they did it but your balance pipe for your exhaust on an 04-later bike sits lower than the frame rails by a few millimetres, so the lift will be raising the exhaust before your chassis.. Run a straight edge across the bottom chassis rails and you will see what I mean.
  • T4
    T4
    I welded a simple frame to a length of 50mm pipe with a 90 degree bend in it; basically made the stand out of scraps. Lifts my Sportster rear wheel about 100mm off the deck (enough to remove rear wheel) and the bike is secure enough to sit on when on the stand. The stand connects to the frame at a tube bolted to rear crossmember with a removable pin, and there is no fouling or lifting on the exhaust.
    Will attempt to attach some pics if I can work this thing right.
    Cheers, Will
  • T4
    T4
    Oh yeah, forgot to add: I can lift the front of the frame with a bottle jack and remove both wheels at the same time and the bike is still stable without using tiedowns.
