Suspension upgrade
Suspension upgrade
Steve L
there has been quite a bit of talk on here lately about suspension and what to use. I did really think about going with a top shelf Ohlins setup but just don't have that much too spend. It would've cost around $4k fitted.
I got onto a local bloke who only does bike suspension. He mainly does race bikes but has been looking into Harleys and other cruisers as he has seen there isn't a big range of good quality components available here in Australia. He has been working with K Tech for many years and they have devoloped a few shocks and fork setups available now. They do a full drop in setup for my front end but it's expensive, around $1450 fitted and they do top end piggy back shocks for about $1800. After having a good chat about what I'm wanting from my bike he made some recommendations. Instead of the full K Tech front end kit he suggested we go with Racetech setup and the non piggy back K Tech shocks. He is going to do it as a ride in ride out for $1950 and guarantees his work.
It will take about 3 weeks for the custom built shocks to arrive from the UK and once here he will do the job as soon as it suits me.
I know this is a bit long winded but I know that there are a few of us that have been looking for a good setup at a reasonable price.
Once done and sorted I will do a review.
I have told him that whether it's good or not I will let everyone know on here how it turns out.
He is keen to get more business from the cruiser market so hopefully it works how I want it to.
TJU
What state you in again Steve ... Are you on the larger side of life if that's ok to ask ... I am and will be courious to see or hear what you think of his work and recommendations .
WideglidingNZ
I'm getting some rear shocks fitted today, they are racingbro's bazooka HD mono r's (the non piggy-back ones), the local Hd dealer is trailing them and gave me a good deal, I will let you know how they go
Steve L
thanks China yeah I know they dont, he tells me he can achieve what I want with the reservoir ones. TJU I am around 85kgs at the moment and they can make them to suit your weight and requirements. I am on the Gold Coast and his business is at Pacific Pines.
Be interesting to hear how you go with your shocks WG.
Benno
Steve, I will be keen to hear how it comes together for you, I have been gathering info/prices on rear suspension for my WG, I have a price from Le Frog for a set of Fournales ($1500) have not heard to many bad things about the product. But I also have been talking with a guy on the sunshine coast about both the piggyback and standard style of Ohlins (standard $1400, piggyback $2100).
Benno
Sorry, added my reply to your last comment, still working out the functions of the site.
Steve L
Yeah I will have to change preload if I load her up to go away anywhere but once the other settings are sorted I don't want to be fiddling with it. It drove me mad with my other Street Glide when I put the YSS shocks on. I was forever adjusting them to try and get them supple enough without too much wallowing. The bloke doing the job is only 15 minutes from home so if not happy I told him I will be back until it's right. I pay half up front then the balance once I'm happy with it.
Steve L
I asked the bloke about 13's and with the sag setup right it would get them close to 12"s.
Steve L
the HD shocks don't have any sag, they are 12"s from centre to centre of the eyelets. That is why they are so harsh.
Steve L
thanks China just the way I explained. I know I need sag but I reckon the shocks/springs I have on now have sfa. They don't move when I sit on the bike. They are the HD ones with the adjustable preload on one of them. I am only short (5'8) so I need to keep the bike as low as I can without compromising ground clearance too much. I think 13" should be a good compromise.
