what do these fit
what do these fit
Steve L
I recently bought these off ebay that were supposed to fit my 2012 Street Glide. They don't and I was wondering if anyone knows what they will fit.
If they don't fit your bike (Brembo brakes ?) , then they will likely fit non-Brembo equipped bikes .
Looks like there are three versions :
http://www.rolandsands.com/product/306/rsd-regulator-lever-set/contrast-cut
Steve L
thanks mate but it would be good to know for sure as I would like to flick them
I Know the 12 runs brembo brakes....
Steve L
the levers are close sort of but the the brake one doesn't have the right bit on it to push the rod in. The clutch ones mounting hole is a bit smaller in diameter. Probably suitable for the non brembo brake models.
Steve L
thanks Drac, any idea if they will fit any other models
