Online: Hilly, softfat
Are there any alternative air cleaners for Low Rider S?
  • Smokey61
    Smokey61
    I may be tempted by a Low Rider S but I'm wondering if there's a more compact air cleaner option than the current drainpipe arrangement. Must be black to match bike and generally weatherproof.
  • brash
    brash
    Yes there are heaps.
    You need a A/C that is compatible with the Throttle By Wire throttle body in 50mm.
    DK customs, S&S, San Diego Customs, HPi Inc etc all make them.
  • srd0060
    srd0060
    Look at the HD catalog
  • fatslim
    fatslim
    Done on the first day of ownership.
    Plenty of leg/knee clearance and doesn't look like a whale cock. SE Ventilator, from a Fatboy Low S. Used on my old 117 Slim and saved.
    The Screamin' Eagle emblazoned sock fitted to the inside, then holes punched for permanent mounting.
    You'll never forget to put it on when its raining and you'll never lose it either.
    No, the sock doesn't affect performance when permanently fitted.
    Any filter that fits on a 110 will work for you.
    Later filled in the slots showing the cheap header pipes.
    This shot shows the profile from a riders perspective.
    From the riders perspective
  • Smokey61
    Smokey61
    A lot of the alternatives seem to have exposed filters, how do they cope with rain, both moving and parked? I was thinking about a black chrome version of this;
  • srd0060
    srd0060
    I used a aircleaner off a 16 Breakout.
