Online: speedzter
How do you tighten the rear indicator bar on an FLHT
  • Nyergen
    Nyergen
    Hi there, my rear indicator bar on the FLHT is loose to the point where I can move the bar up and down. Does anyone know how to tighten this as it is not in the user manual. I think I have to remove the tail light lens and there is a screw in there with the nut being between the wheel and the guard. Any help is greatly appreciated.
    Cheers, Nyergen.
  • Cruise 62
    Cruise 62
    Up under the rear guard 1/2 in. Socket or offset ring spanner will do it
  • Nyergen
    Nyergen
    Thanks mate.
