Starter motor problem 1997 Dyna
Adz69
Hi all. Been noticing the last few days that the starter sometimes free spins without engaging.
Thought at first I was imagining it as it would only be for a split second....but today after work it took until the 3rd try until it engaged and turned the motor over.
Got home. Had a look at some previous posts on here.....sounds like the starter clutch possibly?
yep..Starter clutch. Easy to replace.
