Online: speedzter
Mustang solo seat and fender bib for tourer
  • Steve L
    Steve L
  • Steve L
    Steve L
    I only just bought these but don't like the way it pushes me forward a bit. I paid  $470 for both but you can have them for  $350 plus post if required. I put it up here before they go on Gumtree and Ebay. My loss your gain, if interested call me on 0417590074.
  • Steve L
    Steve L
    decided to keep and get it remodeled to suit
  • shadowarrior
    shadowarrior
    Did you buy the Mustang's new? I had been looking for Mustang Solo tourer for my Sporty, only place I can find them is ordering from US.
  • Steve L
    Steve L
    Yeah mate from the US, cheapest price with freight was on ebay.
  • shadowarrior
    shadowarrior
    Thanks :) Yeah looks like that's the best option for these seats.
  • Steve L
    Steve L
    I had a Mustang solo on my old Dyna and it was the best most comfortable seat I've ever had. I have just bought the above seat but need to get it reworked a little to make it spot on. There are heaps of different seats out there and unfortunately the only way to know if it suits is to ride on it for a few hours. Le Pera aren't generally known for comfort, more for looks.
  • TJU
    TJU
    Hi Steve ... Like yourself I am looking at getting a solo seat for my 2017 Road Glide Special ... Have a Mustang on my 08 Softail and reckon it is pretty dam good .
    Just a curiosity question ... The tab in the pic at rear of seat in the middle , where does that bolt into , do you have to drill a hole in rear guard ... How does seat attach .
  • Steve L
    Steve L
    Yeah it's mounted by the 2 bolts at the front that hold the solo seat in place and the rear is the bolt that holds the standard rear seat down. The main reason I got one was because the HD sundowner seat marked the rear gaurd a bit. I managed to polish most of the marks out though. ??
