HELP ?????? 2007 VRSCDX SE Stage two cams.
CAP_10
Before I go and spend my hard earned $$$.
Thinking of upgrading to the Stage 2 SE cams with 58mm TB & Injectors so I have a quote to get it all done but have had some people say its worth doing and others say it wasn't worth the money.
I have read that bigger TB & Injectors are over kill and to only do the cams and SE tuner others say don't touch it as it wont make much performance difference for the $$$ you would spend.
I was quoted $3500 just for the cams with a dyno & tuner from an independent and quoted $4000 for cams,TB, Inj Tuner & Dyno from Harley.
Who else has done this and was it worth it. You advice & help would be greatly appreciated.
