Online: baldy1450
When bags on a bagger are not enough
  • LOFTYBOB
    LOFTYBOB
    Decided to get a trailer to tow behind the RoadKing (hence the mods to torque the motor up)
    It was pink lol, but the owner's husband is a spray painter and he color matched it to the Gold on my bike.
  • Geoff3DMN
    Geoff3DMN
    A Classic Industries trailer, they're well built those.  A few tips from another trailer owner if you don't mind...
    Get used to doing lot of u-turns, backing trailers when they're hooked up to a bike doesn't work too well.
    Don't forget the extra weight and length when you're overtaking, a loaded trailer will reduce your acceleration, increase your wind drag and you have to allow extra time and space to overtake.
    If you haven't got brakes (and most Classics don't) the try and do your braking in a straight line (so before the corner) because strong braking mid-corner with a loaded trailer can make the bike do things you don't expect.
    Oh... and don't lane split :)
  • Baloffski
    Baloffski
    F"Ken Hell. Thinking if correct weight, there should be a trailer (Or anchor) site on this here forum.
    Makes so much sense in our brown land to cart stuff, and easy sleeping... Never thought would say, but Lofty very glad you brought it up, also glad you changed from "Pink".....!
    Way dat tings going with myself may end living outta my campa Motorcycle Trailer.
    Very good set up Lofty, on the RG. excell. Mick
  • LOFTYBOB
    LOFTYBOB
    Tow ball fitted
    Tow ball off
    Bloody impressed with his workmanship
  • LOFTYBOB
    LOFTYBOB
  • LOFTYBOB
    LOFTYBOB
  • Rivo
    Rivo
    Miniature Hayman Reese.......looks great Lofty
    looks good lofty but you travel light on a bike! LOL small bag enough for a week.
  • Rumpig_63
    Rumpig_63
    Mine is a work in progress, in the painters now to match the bike after having to fill all the holes the previous owner put in it for his DOG. Will be Ember Red Sunglo by the end of the week.
