Online: speedzter
I cracked a Fat..cat
  • Huckleberry
    Huckleberry
    Only about 500m from home a couple of pops and a fart or two from my Fatcat, then BANG! This happens, is it saveable?
  • JFE
    JFE
    That's some bad luck. Any idea what caused it? They are a heavy system.
    D&D also sell parts/spares, but I'm sure a local fix would be cheaper and faster.
    Interested to know how you go sorting it.
    d and d make heavy duty pipes, I have a set on a carb Buell, I would have it gas welded back on or tig welded not mig as would crack again.
  • Daggs
    Daggs
    definitely TIG, done right that weld will be the strongest part of the pipe...
    If your going to try to claim it under a warranty, getting it welded will void a warranty claim, just be aware of that.
