Online:
John.R
"FORD" Branded injector wiring
12Glide
Iv'e just had cams and a dyno on my bike (2012 roadglide)..runs good , but is ideling up the shit..once warmed up it will surge between 1100 and 900 like it wants to stall out.
Anywho.. while checking everything i noticed i have FORD branded injector clips on harness.
Please tell me that's normal ??
12Glide
Mmm..weird.
Not happy..im a Holden man to !!
groover
Harley have used Ford injection parts for a number of years. My previous 2008 Roadking had Ford connections.
It's not the first time Ford and Harley have worked together.
robnicko
what about the surging, have you determined the problem?
Sounds like a vacuum leak possibly after the MAP sensor between it / throttle body and the cylinder head (unmetered air getting in causing erratic idle)
as you mention it does this when hot/warmed up the warmup enrichment can 'hide' vacuum leaks & when warm things expand and that could be when the leak is evident / causing the problematic idle
