Online:
John.R
Replacing the Internal Siren Battery on 07 Fatboy
lewy
Just a heads up as I couldn't find anything that identified where the 9v rechargeable battery for the Internal Srien was
located. It is in behind the plastic rear inner fender. Once you remove the inner fender it is easy to access. You won't need to remove the rear wheel or even jack the bike up. Only took about 30 minutes from go to whoa. Hope this is helpful to other members.
